All About Thru Axles
As a method of securing wheels to frames and forks, thru axles represent a superior concept in theory yet remain muddled in practice due to the inability of the bicycle industry to coalesce around a unified standard. Compared to traditional quick release skewers, thru axles can substantially augment the rigidity of the interface between the hub and the dropouts, while also precisely locating the hub to optimize the alignment between caliper and rotor on disc-equipped bicycles. However, the myriad of extant standards for axle diameter, thread pitch, dropout width, and differing conventions for front versus rear make specification highly complex. Unfortunately, the majority of bicycle manufacturers provide little to no detail on the thru axle standards utilized on their frames, leaving consumers without readily accessible compatibility data. When needing to replace a damaged or lost axle, or upgrade to a higher quality axle, this paucity of information engenders profound frustration. This article aims to elucidate some of the key variables to clarify the landscape.
The Universal Derailleur Hanger (UDH) embodies a significant step toward enhanced innovation and universality in mountain bike components. With its meticulously engineered 12 x 1.0 mm thread pitch to pair with diverse rear suspension topologies and hub spacing conventions, this component enables cross-frame interoperability and seamless integration. The patented design incorporates strategic technical features including a chain retention mechanism for derailleur security, and a rearward-pivoting failure point to safeguard both frame and drivetrain in crashes. Moreover, critical derailleur interface geometries have been harmonized with industry-standard mountain bike derailleurs to guarantee optimized shifting performance. For riders, this equates to simplified replacement and restored drivetrain functionality should damage occur. Rather than proprietary hangers dictating component compatibility, the UDH fit means facile swapping at any bicycle shop.
A Common Misconception: Despite the ubiquity of the DT Swiss brand on thru axle hardware, do not assume your axle adheres to a DT standard. More likely, your axle was manufactured by DT but designed around a different specification by the bicycle OEM.
The E-thru Conundrum: Shimano’s “E-Thru” label encompasses several distinct variants with compatibility dependent on dropout width and threading conventions. For example, the standard 142 mm E-Thru axle may function in many 148 mm Boost E-thru frames, while proving too long for some 142 mm E-thru frames requiring shorter hardware. When replacing, precise length measurements from the existing E-Thru axle rather than assumed standards based on hub spacing offer definitive sizing data.
Sizing: Four key attributes determine appropriate thru axle specification:
- Bolt Head Interface: Flat or conical
- Total Length: The length of the axle, not including the head.
- Thread Length: The length of the axle’s threaded portion.
- Thread pitch: Thread standard used on the axle, expressed as distance between threads in millimeters.
Fits: A list of known compatible forks or frames, by no means comprehensive.
Important Note: Minor variations within standards exist. Generally, any model of the same variant should function correctly barring outliers.
TOP
ROAD FRONT 12 / 15 x 100 | |
MTB FRONT 15 x 100 | MTB FRONT 15 x 110 BOOST |
REAR 12 x 142 | REAR 12 x 148 BOOST |
FRONT ROAD 12 X 100 MM
FRONT ROAD 12 X 100 MM /15 x 100 MM |
FRONT 12 X 1.0 MM
12 X 1.0 (CONICAL) |
114 MM | ||||
Model | Length | Thread Length | Thread Pitch | Interface |
Extralite Blacklock 12.5G | 114 mm | 12.5 mm | 12 x 1.0 mm | Conical |
FITS | ||
SPECIALIZED | ||
SW Aethos (2022+) | SW Tarmac SL8 | SW Crux (2022+) |
SW Venge Disc (2021+) | Tarmac SL8 | Crux (2022+) |
117 MM | ||||
Carbon-Ti EVO X-12 | 117 mm | 14 mm | 12 x 1.0 mm | Conical |
FITS | |
SPECIALIZED | SW Aethos (2021) |
SW Crux (2018-2021) | Crux (2018-2021) |
SW Tarmac SL7/SL6 (2018-2021) | Tarmac SL7/SL6 (2018-2021) |
SW Venge Disc (2018-2020) | Venge Disc (2018-2020) |
12 X 1.5 (FLAT) |
116 MM | ||||
Extralite Blacklock 12.5A | 116 mm | 12.5 mm | 12 x 1.5 mm | Flat |
FITS |
GIANT Road (2018+) |
120 MM | ||||
Carbon-Ti X-Lock 119 mm | 119 mm | 12 mm | 12 x 1.5 mm | Flat |
Carbon-Ti X-Lock EVO 120 mm | 120 mm | 13 mm | 12 x 1.5 mm | Flat |
Extralite 12.5 | 120 mm | 12.5 mm | 12 x 1.5 mm | Flat |
Far and Near Road | 120 mm | 13 mm | 12 x 1.5 mm | Flat |
FITS | ||
BIANCHI | CINELLI | SCOTT |
Aria (2020-21) | Nemo Tig Gravel (2021) | Addict Gravel (2020-21) |
Specialissima (2021) | Pressure (2021) | Foil Disc (2018-2019) |
XR4 Disc (2021) | PARLEE RZ7 | |
PINARELLO Disc (2019) | ENVE Carbon Disc Fork | RIDLEY Noah |
125 MM | ||||
Carbon-Ti EVO 125 mm | 125 mm | 135 mm | 12 x 1.5 mm | Flat |
Extralite Blacklock 12.5B | 125 mm | 14 mm | 12 x 1.5 mm | Flat |
FITS | ||
BIANCHI | CANNONDALE | SCOTT |
Zolder Pro (2019) | Synapse Disc | Addict (2020-21) |
PARLEE | ||
Altum Disc (2020+) | Chebacco (2020+) | TTiR Disc |
Z-Zero Disc/XD |
Colnago
COLNAGO | ||||
Carbon-Ti EVO X-Colnago Front | 117 mm | 10 mm | 12 x 1.5 mm | Conical |
FITS | ||
COLNAGO | ||
C68 (2022+) | C64 (2018-2022) | V4RS (2023) |
V3RS & V3 (2019-‘22) | G3X (2020-‘22) | V2 (2018-2020) |
12 X 1.75 (FLAT) |
118.5 mm (FLAT) | ||||
Carbon-Ti EVO 118.5 mm | 118.5 mm | 10 mm | 12 x 1.75 mm | Flat |
FITS |
TREK Madone Disc SLR Gen 7 |
122 mm (FLAT) | ||||
Carbon-Ti EVO 122 mm | 122 mm | 10.5 mm | 12 x 1.75 mm | Flat |
Extralite Blacklock 12.5E | 122 mm | 12 mm | 12 x 1.75 mm | Flat |
Carbon-Ti 123 mm | 123 mm | 12 mm | 12 x 1.75 mm | Flat |
FITS | ||
TREK | Emonda Disc SLR Gen 6 | Madone Disc SLR Gen 6 |
ROAD
ROAD 15 X 1.0 mm (FLAT) | ||||
Carbon-Ti 15 mm Road | 125 mm | 10 mm | 15 x 1.5 mm | Flat |
FITS | ||
PARLEE | Altum Disc (Pre-2020) | Chebacco (Pre-2020) |
MTB
FRONT MTB 15 X 100 |
FOX 15 X 100 (FLAT) | ||||
Carbon-Ti X-Lock Fox | 146 mm | 11 mm | 14 x 1.5 mm | Flat |
Extralite 15.3 | 146 mm | 11 mm | 14 x 1.5 mm | Flat |
Far and Near Fox | 146 mm | 13 mm | 14 x 1.5 mm | Flat |
KCNC 6061 Fox / E-Thru | 146 mm | 16 mm | 14 x 1.5 mm | Flat |
KCNC 7075 Fox / E-Thru | 146 mm | 16 mm | 14 x 1.5 mm | Flat |
FITS | ||||
FLOAT 32 15QR (2014-2020) | TALAS 32 15QR (2014-2020) | |||
FLOAT 34 15QR (2014-2020) | TALAS 34 15QR (2014-2020) |
MTB
ROCK SHOX 15 X 100 (FLAT) | ||||
Carbon-Ti X-Rock Shox | 147 mm | 10 mm | 15 x 1.5 mm | Flat |
Carbon-Ti EVO Rock Shox | 148 mm | 11.5 mm | 15 x 1.5 mm | Flat |
Extralite 15.4 | 147 mm | 12.2 mm | 15 x 1.5 mm | Flat |
Far and Near Rock Shox | 147 mm | 11 mm | 15 x 1.5 mm | Flat |
KCNC 6061 Maxle | 148 mm | 13.5 mm | 15 x 1.5 mm | Flat |
KCNC 7075 Maxle | 148 mm | 11 mm | 15 x 1.5 mm | Flat |
FITS | |
SID SL – Ultimate / Ult. Brain / Select / Select (+) (2021+) | |
SID Ultimate / Select + / Select (2021+) | |
RS-1 (2015+) | SID WC / XX / RCT3 / RLT / RL (‘12-‘15) |
REBA RLT, RL (2012-‘15) | PIKE DJ / RC / RCT3 / RLT / RL (‘14-‘15) |
REVELATION WC / XX / RCT3 / RLT / RL (‘14-‘15) | |
SANTA CRUZ Stigmata |
DT SWISS 15 X 100 (FLAT) | ||||
*Carbon-Ti X-Lock DT | 144 mm | 17 mm | 15 x 1.5 mm | Flat |
**Extralite 15.1 | 143 mm | 8.7 mm | 15 x 1.5 mm | Flat |
FITS | |
*OPM O.D.L. 100 | **Torsion Box Models Only |
MTB
MAGURA 15 X 100 (CONICAL) | ||||
Extralite 15.5A | 129 mm | 11 mm | 15 x 1.0 mm | Conical |
Extralite 15.5B | 139 mm | 11 mm | 15 x 1.0 mm | Conical |
FITS | |
MAGURA |
MTB
FRONT MTB BOOST 15 X 110 |
FOX BOOST 15 X 110 (FLAT) | ||||
Carbon-Ti X-Lock Fox Boost | 156 mm | 14 mm | 14 x 1.5 mm | Flat |
Carbon-Ti EVO Fox Boost | 155 mm | 13 mm | 14 x 1.5 mm | Flat |
Extralite 15.3B | 156 mm | 14 mm | 14 x 1.5 mm | Flat |
Far and Near Fox Boost | 155 mm | 13 mm | 14 x 1.5 mm | Flat |
KCNC 6061 Fox Boost | 156 mm | 17 mm | 14 x 1.5 mm | Flat |
KCNC 7075 Fox Boost | 156 mm | 16 mm | 14 x 1.5 mm | Flat |
FITS | |
FLOAT | |
32 Step-Cast Boost (2017+) | 32 Boost (2016) |
34 Step-Cast Boost (2017+) | 34 Boost (2016+) |
Not Compatible with Float 36 / 38 Models (2021+) |
MTB
ROCK SHOX MAXLE BOOST 15 X 110 (FLAT) | ||||
Carbon-Ti Rock Shox Boost | 156 mm | 12 mm | 15 x 1.5 mm | Flat |
Carbon-Ti EVO Rock Shox Boost | 158 mm | 11.5 mm | 15 x 1.5 mm | Flat |
Extralite 15.4B | 156 mm | 12 mm | 15 x 1.5 mm | Flat |
Far and Near Rock Shox Boost | 155 mm | 11 mm | 15 x 1.5 mm | Flat |
KCNC 6061 Maxle Boost | 158 mm | 11 mm | 15 x 1.5 mm | Flat |
KCNC 7075 Maxle Boost | 158 mm | 11 mm | 15 x 1.5 mm | Flat |
FITS |
REBA RL Boost (2016-‘20) |
LYRIC RC / RC2 / RCT3 Boost (2016-‘20) |
Not Comp. – SID SL / SID (Ultimate, Brain, Select+, Select) (2021+) / RS-1 |
REAR
REAR 12 X 142 |
12 X 1.0 – SYNTACE / X-12 (12 x 142) |
160 MM (CONICAL) | ||||
Carbon-Ti X-Lock EVO | 159 mm | 16.5 mm | 12 x 1.0 mm | Conical |
Extralite 12.2 | 160 mm | 17 mm | 12 x 1.0 mm | Conical |
FITS | |
CANNONDALE | CANYON Lux CF (2014-‘15) |
Scalpel 29er (2013-‘15) | Gran Canyon CF (2014-‘15) |
SPECIALIZED | |
SW Aethos (2021) | SW Crux / Crux (2019+) |
SW Epic (2011-‘17) | SW Stumpjumper HT (2015-‘16) |
SW Venge / Venge (2019-‘20) | Tarmac SL7 / SL6 |
12 X 1.5 – E-THRU STYLE 12 x 1.5 (12 x 142) |
158 MM | ||||
Carbon-Ti EVO 158 mm | 158 mm | 13.5 mm | 12 x 1.5 mm | Flat |
Extralite 12.4 RA | 158 mm | 13 mm | 12 x 1.5 mm | Flat |
KCNC 7075 E-Thru 161 mm | 161 mm | 18 mm | 12 x 1.5 mm | Flat |
FITS | |
SCOTT Road Pre-2020 | Addict Gravel (2019-‘21) |
COLNAGO (159.7 mm) | ||||
Carbon-Ti EVO X-Colnago Rear | 159.7 mm | 13 mm | 12 x 1.5 mm | Conical |
FITS | ||
COLNAGO | ||
163 MM | ||||
Carbon-Ti EVO 163 mm | 163 mm | 15 mm | 12 x 1.5 mm | Flat |
Extralite 12.4 RB | 163 mm | 13 mm | 12 x 1.5 mm | Flat |
FITS | |
GIANT Road Pre-2020 | PINARELLO Dogma F |
166 mm | ||||
Carbon-Ti 166 mm | 166 mm | 18 mm | 12 x 1.5 mm | Flat |
Carbon-Ti EVO 166 mm | 166 mm | 17 mm | 12 x 1.5 mm | Flat |
KCNC 7075 167 mm | 167 mm | 18 mm | 12 x 1.5 mm | Flat |
KCNC 6061 167 mm | 167 mm | 19 mm | 12 x 1.5 mm | Flat |
FITS | ||
BIANCHI | ||
Oltre XR4 Disc (2019+) | Specialissima Disc(2021) | Zolder Pro (2023) |
CINELLI Pressure (2021) | PINARELLO Prince Disk (’19) | RIDLEY Noah |
BASSO Noah | Palta (2020) | Diamante SV (2021) |
168.7 mm | ||||
Carbon-Ti EVO 168.7 mm | 168.7 mm | 17 mm | 12 x 1.5 mm | Flat |
FITS |
SCOTT Addict (2020+) |
172 mm | ||||
Carbon-Ti E-Thru | 171 mm | 17 mm | 12 x 1.5 mm | Flat |
Carbon-Ti EVO 172 mm | 172 mm | 17 mm | 12 x 1.5 mm | Flat |
Extralite 12.1 | 172 mm | 18 mm | 12 x 1.5 mm | Flat |
KCNC 7075 171 mm | 171 mm | 18 mm | 12 x 1.5 mm | Flat |
KCNC 6061 172 mm | 172 mm | 19 mm | 12 x 1.5 mm | Flat |
FITS | |||
CINELLI Nemo Tig Gravel (2021+) | GUERCIOTTI Eureka CX (2022+) | ||
BMC | FourStroke FS01 (2013-‘15) | FourStroke FS02 (2013) | |
FOCUS Super Bud 29r (2014) | GT Zaskar 100 (2013) | ||
GIANT | Anthem Adv. 27.5 (2015) | XtC Advanced SL (2014-‘15) | |
LAPIERRE | Zesty (2014) | Spicy (2014) | |
TITICI | Explosion (2013-‘15) | Flexy (2014-‘15) | |
ROCKY MOUNTAIN | Element 950 RSL 29 (2014) | Vertex Carbon 29 (2012) | |
YETI | |||
SB6 Carbon (2015-2016) | SB4.5C Boost 148 (2016) | SB5.5C Boost (2016) |
12 X 1.75 – MAXLE STYLE 12 x 1.75 (12 x 142) |
165 mm (FLAT) 12 x 135-142 | ||||
Carbon-Ti Maxle 135 | 167 mm | 20 mm | 12 x 1.75 mm | Flat |
Carbon-Ti EVO 165 mm | 165 mm | 22 mm | 12 x 1.75 mm | Flat |
Extralite 12.4 RE | 166 mm | 19 mm | 12 x 1.75 mm | Flat |
FITS | ||
TREK | ||
Emonda Disc (2018-‘22) | Madone Disc (2018-‘22) | Madone SLR Gen 7(2023+) |
COLNAGO Prestige (2017) | WILIER 101FX (2017) | RIDLEY Noah SL Disc (2017) |
174 MM (FLAT) 12 x 142 – 148 | ||||
Carbon-Ti Maxle | 174 mm | 20 mm | 12 x 1.75 mm | Flat |
Carbon-Ti EVO 174 mm | 174 mm | 20 mm | 12 x 1.75 mm | Flat |
Extralite 12.3 | 176 mm | 19 mm | 12 x 1.75 mm | Flat |
Far and Near Maxle | 172 mm | 20 mm | 12 x 1.75 mm | Flat |
KCNC 7075 Maxle | 173 mm | 21 mm | 12 x 1.75 mm | Flat |
FITS | |
BMC FourStroke FS02 (2014) | WILIER 101XN (2014) |
IBIS | |
Mojo SL-R (2013) / Mojo HDR (2014) / Ripley (2013) | |
KTM | |
Myroon Prestige, Prime, Master, Elite / Scarp Prestige, Prime Master, Elite (‘15) | |
NINER RIP9 (2013-2015) | NINER SIR9 (2015-2016) |
TREK | |
Procaliber 9.9 SL / 9.8 SL / 9.7 (2016) | Superfly 9.9 SL / 9.8 (2013-2015) |
Superfly 9.7 (2015) |
TOP
REAR 12 X 148 BOOST |
BOOST 12 x 1.0 (12 x 148) (UDH) |
12 X 1.5 – E-THRU BOOST STYLE 12 x 1.5 (12 x 148) |
12 X 1.75 – MAXLE BOOST STYLE 12 x 1.75 (12 x 148) |
Rear Maxle 12×135 | ||||||
Manufacturer | Model | Interface | Length | Pitch | Thread Length | Notes |
Carbon-Ti | X-Lock X-Maxle 135 | Flat | 167 | 12×1.75 | 20mm | |
Fits: Specialized Crux (2016) |
Rear Maxle 12×142 | ||||||
Carbon-Ti | X-Lock X-Maxle | Flat | 174mm | 12×1.75 | 20mm | |
Extralite | Blacklock 12.3 – Maxle | Flat | 176mm | 12×1.75 | 19.2mm | |
Far and Near | Maxle | Flat | 172mm | 12×1.75 | 20mm | |
Kcnc | Low Profile – Maxle | Flat | 173mm | 12×1.75 | 21mm | |
Kcnc | Indexing – Maxle | Flat | 173mm | 12×1.75 | 21mm | |
Kcnc | QR – Maxle | Flat | 172mm | 12×1.75 | 21mm | |
Fits: BMC FourStroke FS02 (2014) Ibis Mojo SL-R (2013) Ibis Mojo HDR (2014) Ibis Ripley (2013) KTM Myroon Prestige, Prime, Master, Elite 27 and 29 (2015) KTM Scarp Prestige, Prime Master, Elite 27 and 29 (2015) Niner RIP9 (2013-2015) Niner SIR9 (2015-2016) Trek Procaliber 9.9 SL, 9.8 SL, 9.7 SL (2016) Trek Superfly 9.9 SL (2013-2015) Trek Superfly 9.8 (2013-2015) Trek Superfly 9.7 (2015) Wilier 101XN (2014) |
Maxle Boost/DH 12×148/150 | ||||||
Carbon-Ti | X-Lock X-Maxle 150 | Flat | 182mm | 12×1.75 | 20mm | |
Extralite | BlackLock 12.3B – Maxle Boost | Flat | 182mm | 12×1.75 | 20mm | |
Far and Near | Maxle Boost | Flat | 182mm | 12×1.75 | 20mm | |
KCNC | 6061 Maxle Boost | Flat | 180mm | 12×1.75 | 22mm | |
Fits: Niner RKT 9 RDO (Boost 148) (2016) Many other Boost Maxle frames |
Maxle ABP (Trek) 12×142 | ||||||
Carbon-Ti | X-Lock X-Maxle ABP | Flat | 192mm | 12×1.75 | 20mm | |
Fits: Trek Remedy 9.8 27,5 (2016) Trek Remedy 9, 8 (2016) Trek Superfly FS (2014-2015) Trek Fuel EX (2014-2015) Trek Slash (2014-2015) |
Maxle ABP Boost (Trek) 12×148 | ||||||
Carbon-Ti | X-Lock X-Maxle ABP Boost | Flat | 198mm | 12×1.75 | 20mm | |
Fits: Trek Top Fuel 9.9 SL, 9.8 SL (2016) Trek Top Fuel 9, 8 (2016) Trek Remedy 29 Carbon (2016) Trek Fuel EX 9.9, 9.8 29 (2016) Trek Fuel EX 9, 8 29 (2016) |
Rear “Scott” Standard 12×142 | ||||||
Carbon-Ti | X-Lock X-Scott | Flat | 168mm | 12×1 | 16mm | |
Extralite | Blacklock 12.4 – Scott | Flat | 168mm | 12×1 | 17.2mm | |
Far and Near | Scott | Flat | 168mm | 12×1 | 17mm | |
Tune | DC12 – Scott | Flat | 168mm | 12×1 | 12mm | |
Fits: Carbon-Ti and Far and Near. Note Extralite does not fit Santa Cruz models Lynskey Pro 29 (2015) Santa Cruz 5010 (2014-2015) Santa Cruz 5010 V2 (2016) Santa Cruz Blur XC Carbon (2013) Scott Spark 700 (2014-2015) Scott Spark 900 (2014-2015) Scott Scale 700 (2014-2015) Scott Scale 900 (2014-2015) Extralite version does not work on Santa Cruz frames |
Rear “Scott” Boost Standard 12×148 | ||||||
Extralite | BlackLock 12.4B – Scott Boost | Flat | 172mm | 12×1 | 17.2mm | |
Fits: Scott Boost Frames |
Rear Shimano E-thru 12×142 | ||||||
Carbon-Ti | X-lock E-thru | Flat | 171mm | 12×1.5 | 17mm | |
Extralite | Blacklock 12.1 – E-thru | Flat | 172mm | 12×1.5 | 18.3mm | |
Far and Near | E-thru | Flat | 169mm | 12×1.5 | 18mm | |
Kcnc | Low Profile – E-Thru 171 | Flat | 171mm | 12×1.5 | 18mm | |
Kcnc | Indexing – E-thru | Flat | 171mm | 12×1.5 | 18mm | |
Kcnc | QR – E-thru | Flat | 170mm | 12×1.5 | 14mm | |
Fits: BMC FourStroke FS01 (2013-2015) BMC FourStroke FS02 (2013) Focus Super Bud 29r (2014) Giant Anthem Advanced 27.5 (2015) Giant XtC Advanced SL 27.5 (2014-2015) GT Zaskar 100 (2013) Haibike Greed (2012) Kona King Kahuna 29er (2003) Lapierre Zesty (2014) Lapierre Spicy (2014) Titici Explosion (2013-2015) Titici Flexy (2014-2015) Rocky Mountain Element 950 RSL 29″ (2014) Rocky Mountain Vertex Carbon 29″ (2012) Yeti SB6 Carbon (2015-2016) Yeti SB4.5C Boost 148 (2016) |
Rear Shimano E-thru Short (161) 12×142 | ||||||
Kcnc | Low Profile – E-thru 161 | Flat | 161mm | 12×1.5 | 18mm | |
Fits: None listed |
Rear Shimano E-thru Long (Boost) 12×148 | ||||||
Carbon-Ti | X-Lock – E-thru Boost | Flat | 178mm | 12×1.5 | 18mm | |
Extralite | BlackLock 12.1B – E-thru Boost | Flat | 178mm | 12×1.5 | 18.3mm | |
Far and Near | E-thru Boost | Flat | 180mm | 12×1.5 | 18mm | |
KCNC | 6061 E-thru Boost | Flat | 177mm | 12×1.5 | 19mm | |
Fits: None listed |
Rear X-12 (Syntace) 12×142 | ||||||
Carbon-Ti | X-Lock X-12 | Tapered | 159mm | 12×1 | 16.5mm | |
Extralite | Blacklock 12.2 – Specailized X-12 | Tapered | 161mm | 12×1 | 17.2mm | |
Kcnc | Low Profile – Syntace X-12 | Tapered | 163mm | 12×1 | 18mm | |
Kcnc | QR – DT Swiss (X-12) | Tapered | 159mm | 12×1 | 15mm | |
Kcnc | Indexing – Syntace X12 | Tapered | 167mm | 12×1 | 19mm | |
Tune | DC12 – Syntace X12 | Tapered | 159mm | 12×1 | 16.5mm | |
Fits: Cannondale Scalpel 29er (2013-2015) Canyon Lux CF (2014-2015) Canyon Gran Canyon CF (2014-2015) Specialized S-Works Epic (2011-2017) Specialized S-Works Stumpjumper HT (2015) |
Rear X-12 Boost (Syntace Boost) 12×148 | ||||||
Carbon-Ti | X-Lock X-12 Boost | Tapered | 166mm | 12×1 | 17.5mm | |
Extralite | Blacklock 12.2B – Specailized X-12 Boost | Tapered | 166mm | 12×1 | 17.2mm | |
Fits: Specialized S-Works Epic HT (2017) Specialized Epic HT (2017) |
