ENVE x Open UP Special Edition
With so much pallete work already done by ENVE and OPEN, the goal with this build was to continue the clean aesthetics and tranform it into a very functional, fast, and (most importantly, fun) gravel bike.
With some slight modification to the stock ENVE Compact handlebars, we were able to mount Shimano’s EW-RS910 A-Junction box the the handlebar and almost completely hide the wiring at the front end of the bike. The wire connection to the B-junction is attached to the rear brake hose with electrical heat-shrink tubing from the handlebar to OPEN’s clever universal headtube entry point.
The Ultegra R8070 1×11 drivetrain is equipped with Praxis’ newest Zayante Carbon crankset and a 42-tooth direct mount ring, with an XT M8050 rear derailleur and 11-40 cassette to provide a respectable gear range to tackle the rugged gravel roads of Southern Arizona.
ENVE’s G23 gravel-specific wheels are with custom orange rim and hub decals to match the U.P.’s attractive colorway. These Enve wheels are no mere ornaments, however, with ultra-reliable DT Swiss 240s hubs laced to ENVE’s incredibly lightweight and purpose-driven G23 carbon rims.
| Build List | |
| Frame / Fork | 52cm OPEN U.P. – ENVE Special Edition |
| Cranks | Praxis Works Zayante, Direct Mount, Wave Tech, 42t, 170mm |
| BB | Praxis M30 BB386 EVO |
| Pedals | Shimano XT M8000 |
| Handlebars | ENVE Compact 42cm |
| Handlebar Tape | LizardSkin DSP |
| Shift Levers | Shimano Ultegra R8070 |
| Housing / Cables | Hydraulic |
| Stem | ENVE 110mm |
| Saddle | Brooks Carbon Cambium C13 |
| Seatpost | ENVE 27.2 zero Custom Decals |
| Headset | Cane Creek 40 |
| Expander | ENVE |
| Top Cap | Fair Wheel Carbon |
| Spacers | Fair Wheel Carbon |
| Front Derailleur | N/A |
| Rear Derailleur | Shimano XT M8050 |
| Chain | KMC X11 SL |
| Brakes | Shimano Ultegra R8070 |
| Brake Rotors | Shimano Dura Ace |
| Seat Collar | OPEN U.P. |
| Bottle Cages | Fair Wheel UD Gloss |
| Wheelset | |
| Front Hub | DT Swiss 240 12×100 with Custom Decals |
| Rear Hub | DT Swiss 240 12x142with Custom Decals |
| Rims | ENVE G-23 Custom Decals |
| Spokes | Straight Pull Sapim CX-Ray |
| Skewers | Carbon-Ti 12mm Thru |
| Cassette | Shimano XT M8000 11-40 |
| Tires | Schwalbe G-One AllAround Tubeless |
